зависи за кој микреоконтролер, доколку микреоконтролерот има вграден PWM излез има хардверски библиотеки, доколку нема, треба да се програмира софтверски одреден излез да добие карактеристики на PWM
ова ти е од хелп фајлот од µBasic PRO for PIC на микроелектроника
program PWM_Test
dim current_duty, current_duty1, old_duty, old_duty1 as byte
sub procedure InitMain()
ANSEL = 0 ' Configure AN pins as digital I/O
ANSELH = 0
PORTA = 255
TRISA = 255 ' configure PORTA pins as input
PORTB = 0 ' set PORTB to 0
TRISB = 0 ' designate PORTB pins as output
PORTC = 0 ' set PORTC to 0
TRISC = 0 ' designate PORTC pins as output
PWM1_Init(5000) ' Initialize PWM1 module at 5KHz
PWM2_Init(5000) ' Initialize PWM2 module at 5KHz
end sub
main:
InitMain()
current_duty = 16 ' initial value for current_duty
current_duty1 = 16 ' initial value for current_duty1
PWM1_Start() ' start PWM1
PWM2_Start() ' start PWM2
PWM1_Set_Duty(current_duty) ' Set current duty for PWM1
PWM2_Set_Duty(current_duty1) ' Set current duty for PWM2
while (TRUE) ' endless loop
if (RA0_bit <> 0) then ' button on RA0 pressed
Delay_ms(40)
Inc(current_duty) ' increment current_duty
end if
if (RA1_bit <> 0) then ' button on RA1 pressed
Delay_ms(40)
Dec(current_duty) ' decrement current_duty
end if
if (RA2_bit <> 0) then ' button on RA2 pressed
Delay_ms(40)
Inc(current_duty1) ' increment current_duty1
end if
if (RA3_bit <> 0) then ' button on RA3 pressed
Delay_ms(40)
Dec(current_duty1) ' decrement current_duty1
end if
Delay_ms(5) ' slow down change pace a little
wend
end.
