Author Topic: Туторијал за програмирање во MikroBasic (LCD дисплеј)  (Read 1537 times)
« Opened on 26.06.2011, Sunday, 21:40:32 (Edited 26.06.2011, Sunday, 21:43:33) »
Главна страна (дискусии, прашања)
http://elektronika-mk.net/index.php?topic=4291.msg39377#msg39377
После подолго време породолжувам со туторијалите, се извинувам на сите но немав време поради школувањето  :D
Шема
Код
'************* TUTORIAL IV - LCD **********
'********* Makedonski Forum za Elektronika********
'********* http://elektronika-mk.net **********
'********* Procesor PIC16F628A @ 4MHz, Simulacija ISIS 7, Razvoen sistem MFE_01
'************** DEVIL ****************
program LCD_kontrola
' Lcd modul konekcii
dim LCD_RS as sbit at RB0_bit                      'Sertiranje na portite kako RS pin od displejot
    LCD_EN as sbit at RB1_bit                      'Setiranje na EN pin
    LCD_D4 as sbit at RB2_bit                      'Setiranje na D4 pin
    LCD_D5 as sbit at RB3_bit                      'Setiranje na D5 pin
    LCD_D6 as sbit at RB4_bit                      'Setiranje na D6 pin
    LCD_D7 as sbit at RB5_bit
    LCD_RS_Direction as sbit at TRISB0_bit          'Postavuvanje na izlezni pinovi
    LCD_EN_Direction as sbit at TRISB1_bit          ' -------||------
    LCD_D4_Direction as sbit at TRISB2_bit          ' -------||------
    LCD_D5_Direction as sbit at TRISB3_bit          ' -------||------
    LCD_D6_Direction as sbit at TRISB4_bit          ' -------||------
    LCD_D7_Direction as sbit at TRISB5_bit          ' -------||------
' kraj na konekcijata
'Tekst komandi                                      'Ova se poraki koj se prikazuvaat na LCD
dim tekst1 as char[13]                              ' tekst1- ime na tekstot char[13]- dolzina na tekstot
    tekst2 as char[16]                              'Ova sledi za site 12 poraki isto ime na tekstot
    tekst3 as char[13]                              'dolzina na tekstot, gledajte da go sobira vo eden red,
    tekst4 as char[7]                               'inaku nema da bide prikazan toj del od tekstot
    tekst5 as char[8]                               'ke bide otkinat od porakata, premestete vo 2 red
    tekst6 as char[15]
    tekst7 as char[5]
    tekst8 as char[7]
    tekst9 as char[5]
    tekst10 as char[6]
    tekst11 as char[5]
    tekst12 as char[4]
    i    as byte                 ' Promenliva
 '*********TON***************        Postavuvanja za zvuk
Sub procedure TonA()                 'TonotA e so frekvencija 400Hz i trae 300mS
Sound_Play(400,300)
end sub
Sub procedure TonB()                 'TonotB e so frekvencija 1kHz i trae 300mS
sound_play(1000,300)
end sub
      '*********ALARM*************
Sub procedure Alarm()                  'Povtoruvanje na dvata tonovi so cel da se dobie melodija
Delay_ms(300)
PORTA.2 = 1                            'Setiranje na RA2 na visoko nivo
Lcd_Cmd(_LCD_CLEAR)                    'Brisenje na momentalnata poraka od displej
Lcd_out(1,6,tekst9)'Isprakjanje na poraka vo I red od displejot pocnuvajki od 6-to pole, se ispisuva tekst9
TonA() TonB() TonA() TonB() TonA() TonB() TonA() TonB() TonA() TonB()
   delay_ms(300)
    PORTA.2 = 0                     'Se isklucuva RA2
end sub
'********* TEST ALARM************
sub procedure Test()                  'Test Alarm funkcija
 Delay_ms(300)                        'Pauza 300mS
 Lcd_Cmd(_LCD_CLEAR)                  'Se brisi momentalna poraka od LCD
Lcd_out(1,7,tekst12)                  'Se ispraka tekst12 na displej, vo prv red pocnuvajki od 7 pole
Lcd_out(2,6,tekst9)                   'Se ispraka tekst9 vo vtor red pocnuvajki od 6 pole
delay_ms(100)
PORTA.2 = 1                           'Se vklucuva porta RA2
TonA() TonB() TonA() TonB() TonA() TonB() TonA() TonB() TonA() TonB()   'Mini melodija
 Delay_ms(300)
 PORTA.2 = 0                         'Se isklucuva porta RA2
 end sub
 '**********INFO**********
 sub procedure Info()                 'INFO porakata koja se pojavuva na pocetokot
      Delay_ms(500)                   'Procedura na ispisuvanje na displej ista
      Lcd_cmd(_LCD_CLEAR)             'prvo se oznacuva vo koj red (I ili II) pa od koe pole
      Lcd_out(1,6,tekst11)            'i na kraj koja poraka treba da se ispise
      Lcd_out(2,1,tekst3)
      Delay_ms(2000)
      Lcd_cmd(_LCD_CLEAR)
      Lcd_out(2,2,tekst4)
      Delay_ms(2000)
      Lcd_cmd(_LCD_CLEAR)
      Lcd_out(2,6,tekst8)
      Delay_ms(2000)
      Lcd_cmd(_LCD_CLEAR)
      Lcd_out(2,1,tekst6)
      Delay_ms(2000)
      Lcd_cmd(_LCD_CLEAR)
      Lcd_out(2,6,tekst7)
      Delay_ms(2000)
      Lcd_cmd(_LCD_CLEAR)
      lcd_out(2,5,tekst5)
      Delay_ms(2000)
      Lcd_cmd(_LCD_CLEAR)
      Lcd_out(2,1,tekst6)
      Delay_ms(2000)
      Lcd_cmd(_LCD_CLEAR)
      Lcd_out(2,6,tekst7)
      delay_ms(2000)
      Lcd_Cmd(_LCD_CURSOR_OFF)
      lcd_out(1,2,tekst1)
      Lcd_out(2,1,tekst2)
     Delay_ms(200)
     end sub
  '******** GLAVNA PROGRAMA *************
main:                   'Glavna programa kade sto se postavuvanjata na pinovite za vlezni i izlezni
TRISB = %00000011
PORTB = 0
TRISA = %110000
PORTA = %100000
CMCON = 0x07
Sound_Init(PORTA, 3)
'******* TEKST ZA LCD ***********
tekst1 = "Cekam Naredba"           'Tekstovite koj se ispisuvaat na LCD
tekst2 = "Za Info Kopce A"         'Mora da bidat so ist broj na bukvi kako sto se navedeni pogore
tekst3 = "Za Test Alarm"           'Vo broenjeto se smeta i praznoto mesto
tekst4 = "Kopce B"
tekst5 = "Za Izlez"
tekst6 = "Pritisni Crveno"
tekst7 = "Kopce"
tekst8 = "Za STOP"
tekst9 = "ALARM"
tekst10 = "PROEKT"
tekst11 = "INFO:"
tekst12 = "TEST"
Delay_ms(300)
Lcd_Init()                'Komanda za da se inicira LCD-to
Lcd_Cmd(_LCD_CLEAR)         'Se brisi za sekoj slucaj da ne ima nesto random
Lcd_Cmd(_LCD_CURSOR_OFF)    'Se isklucuva kursorot
lcd_out(1,2,tekst1)         'poraka koja se prikazuva vo prv red
Lcd_out(2,1,tekst2)         'poraka koja se prikazuva vo vtor red
delay_ms(500)
while TRUE                 'Proverka za kopcinja ili alarm
      if (Button(PORTB,6,1,1)) then   'Dokolku se pritisni ova kopce mcu-to odi vo INFO mod
          Info()
          while (RB6_bit <> 0)
            nop
          wend
      end if
      if (Button(PORTB,7,1,1)) then
         Test()                       'Dokolku se pritisni ova kopce odi vo TEST mod
          while (RB7_bit <> 0)
            nop
          wend
      end if
      if PORTA.1 = 1 then
      Alarm()                          'Ova e SENZOR, dokolku se pojavi visoko
          while (RA1_bit <> 0)         'nivo togas se aktivira Alarmot
            nop
          wend
      end if
    wend
end.       'Kraj na programata
Видео
LCD tutorial 1
