Add device ID,Menu,Table index :28F002/004/200/400BX-x (TSOP40A,TSOP48 8/16bit, PSOP44) Version 098D5
Fixed Program Config PIC16F8x, PIC16F62x, PIC16F87x
- Fixed ID PIC18F84A (Test on PIC16F84, PIC16F84A, PIC16F627/628/628A, PIC16F872/877)
Fixed Timming Programming PIC12C5xx (Run on Windows XP) Test on PIC12C509JW UV erase), PIC16C505JW (UV erase),PIC12F509 (select device = PIC12C509A)
Add PIC microchip 14bit PIC12F629/675 , PIC16F630/676 , PIC12F635/683 , PIC16F636/684/688 , PIC16F72/73/74/76/77 , PIC16F737/747/767/777 , PIC16F87/88 , rfPIC12F675x , PIC16F785/PS200 , PIC16F716
Add microchip 14bit OTP PIC12C671 , PIC12C672 , PIC12CE673 , PIC12CE674 , PIC16C61/71 , PIC16C62/64/65/73 , PIC16C62A/62B/62C/63/63A/64A/65A/65B/66/67 , PIC16C72/72A/73A/74A/74B/76/77 , PIC16C620/620A/621/621A/622/622A , PIC16CE/623/624/625 , PIC16C710/711/712/716 , PIC16C773/774 , PIC16C745/765/923/924 , PIC16C925/926 , PIC16C554/556/557/558 , PIC16C432/433 , PIC16C717/770/771/781/782
Add PIC microchip 12bit (FLASH memory) PIC12F508/509 , PIC10F200/202/204/206 , PIC16F505 , PIC16F54/57
Add PIC18Fxxx PIC18F242 , 18F248 , 18F252 , 18F258 , 18F442 , 18F448 , 16F452 , 16F458 PIC18F1220 , 18F2220 , 18F4220 , 18F1320 , 18F2320 , 18F4320 PIC18F6520 , 18F6620 , 18F6720 , 18F8520 , 18F8620 , 18F8720 PIC18F2331 , 18F2431 , 18F4331 , 18F4431
PIC18F6525 , 18F6621 , 18F8525 , 18F8621 PIC18F6585 , 18F6680 , 18F8585 , 18F8680
PIC18F2439 , 18F2539 , 18F4439 , 18F4539 PIC18F6410 , 18F8410 , 18F6490 , 18F8490
-Add PIC18Fxxx PIC18F2410 , PIC18F2420 , PIC18F2455
PIC18F2510 , PIC18F2515 , PIC18F2520 , PIC18F2525 , PIC18F2550 , PIC18F2585
PIC18F2610 , PIC18F2620 , PIC18F2680
PIC18F4410, PIC18F4420 , PIC18F4455
PIC18F4510 , PIC18F4515 , PIC18F4520 , PIC18F4525 , PIC18F4550 , PIC18F4585
PIC18F4610 , PIC18F4620 , PIC18F4680
Add Find and edit value OSCCAL (PIC12F629/675 , PIC16F630/676)
Add Edit config at address 0x2008,0x2009 (PIC12F635/683 , PIC16F636/684/688 , PIC16F785)
Fixed Programming PIC all Test on chip
PIC12F675 , PIC16F676 , PIC16F684 ,PIC16F767, PIC16F74
PIC16F872 , PIC16F876 , PIC16F877, PIC16F876A, PIC16F873A, PIC16F819
PIC16F84 , PIC16F84A , PIC16F628, PIC16F628A, eprom PIC12C509JW , PIC16C505JW , PIC16C711JW , PIC16CE625JW
PIC18F458 , PIC18F4320 , PIC18LF258 , PIC18F4539 , PIC18F4431
- Fixed Write/read/verify EEPROM 18F4550
- Fixed Bug program 18Fxxx run on Windows XP/2000 (test PIC18F4539 , PIC18F2680 , PIC18F2431 , PIC18F258 , PIC18F4220 , PIC18F4550)
Add find OSCCAL 10Fx00, 12F50x, 12F6xx (test PIC10F202, 12F509, 12F675) Version 0.98D2 ( PCB3B/PCB35 And PCB4C [0.98D2] ) (5/July/2005)
- Fixed Bug program 18Fxxx run on Windows XP/2000 (test PIC18F4539, PIC18F2680, PIC18F2431 PIC18F258, PIC18F4220, PIC18F4550)
Fixed Programm AT89C8253 (Want modify Adapter MCS-51) (test on AT89S8253); Version 0.98c ( PCB3B/PCB35 [0.98c] )
Add PIC microchip 14bit PIC12F629,PIC12F675, PIC16F630, PIC16F676 ,PIC12F635, PIC12F683, PIC16F636, PIC16F684, PIC16F688
PIC16F72/73/74/76/77, PIC16F737/747/767/777,PIC16F87/88, rfPIC12F675x, PIC16F785/PS200, PIC16F716
Add microchip 14bit,12bit OTP
PIC12C671,PIC12C672,PIC12CE673,PIC12CE674
PIC16C61/71,PIC16C62/64/65/73, PIC16C62A/62B/62C/63/63A/64A/65A/65B/66/67
PIC16C72/72A/73A/74A/74B/76/77, PIC16C620/620A/621/621A/622/622A
PIC16CE/623/624/625, PIC16C710/711/712/716, PIC16C773/774, PIC16C745/765/923/924,PIC16C925/926
PIC16C554/556/557/558, PIC16C432/433, PIC16C717/770/771/781/782
PIC12F508/509, PIC10F200/202/204/206,PIC16F505, PIC16F54/57
Add PIC18Fxxx
PIC18F242,18F248,18F252,18F258,18F442,18F448,16F452,16F458
PIC18F1220,18F2220,18F4220,18F1320,18F2320,18F4320
PIC18F6520,18F6620,18F6720,18F8520,18F8620,18F8720
PIC18F2331,18F2431,18F4331,18F4431
PIC18F6525,18F6621,18F8525,18F8621
PIC18F6585,18F6680,18F8585,18F8680
PIC18F2439,18F2539,18F4439,18F4539
PIC18F6410,18F8410,18F6490,18F8490
Add PIC18Fxxx
PIC18F2410, PIC18F2420, PIC18F2455
PIC18F2510, PIC18F2515, PIC18F2520, PIC18F2525, PIC18F2550, PIC18F2585
PIC18F2610, PIC18F2620, PIC18F2680
PIC18F4410, PIC18F4420, PIC18F4455
PIC18F4510, PIC18F4515, PIC18F4520, PIC18F4525, PIC18F4550, PIC18F4585
PIC18F4610, PIC18F4620, PIC18F4680
Add Find and edit value OSCCAL (PIC12F629/675, PIC16F630/676)
Add Edit config at address 0x2008,0x2009 (PIC12F635/683,PIC16F636/684/688,PIC16F785)
Test on chip
PIC12F675, PIC16F676, PIC16F684 ,PIC16F767, PIC16F74
PIC16F872, PIC16F876, PIC16F877, PIC16F876A, PIC16F873A, PIC16F819
PIC16F84, PIC16F84A, PIC16F628, PIC16F628A,
eprom PIC12C509JW, PIC16C505JW, PIC16C711JW, PIC16CE625JW
PIC18F458, PIC18F4320, PIC18LF258, PIC18F4539, PIC18F4431
Овие и многу други.
Споено мислење: [time]21 Декември 2010, 00:48:06[/time]
Погледај и на ова линк:
http://www.sivava.com/index.html
Кодирај линкови !
Како да кодирате линкови:
http://elektronika-mk.net/index.php?topic=92.0
