Author Topic: се продава жичен рутер!!  (Read 531 times)
Offline donis92
« Opened on 17.11.2011, Thursday, 23:45:06 (Edited 26.11.2011, Saturday, 01:17:48) »
Features
Share your broadband Internet connection among 4 computers
Built-in DHCP server for automatic configuration of LAN IP addresses
Built-in powerful firewall preventing your LAN from attacks via Internet
Built-in WEB-server providing interface for easy installation and management
Supports PPPoE Auto-connect and Auto-disconnect
Supports NAT & IP routing
Specifications
Supports 1xWAN and 4xLAN 10/100Mbps ports
Supports DHCP/Static IP/PPPoE/PPTP/L2TP client
Supports IP Filter, URL Filter, Port Filter and MAC Address Filter
Supports TCP/IP, PPPoE, DHCP, ICMP, NAT, SNTP, ARP Protocols
Supports Time Schedule, MAC Address CLONE, Static Route, Dynamic DNS
Supports UPnP, Virtual Server and Port Mapping
Supports DMZ host, VPN Passthrough for IPSec, PPTP and L2TP Protocols
Built-in network diagnostics tools
Supports Remote and Web Management
Supports security logs
Dimensions: 145x92x35mm
Product weight: 165g
Power supply adapter: 9VDC, 1A
Consumption: up to 12W
Storage conditions: temp. -40...70 Celsius degrees, humidity: 5-90% RH non-condensing
Operating conditions: temp. 0...40 Celsius degrees, humidity: 10-90% RH non-condensing
цена по пп и договор,скрос нов е дали е еден месец користен
d.t
Offline donis92
може и замена за графичка карта на агп над фх6200 со мала доплата од моја страна
d.t
