Author Topic: Минијатурна рачна станица од TALKCOOP  (Read 1889 times)
« Opened on 02.01.2016, Saturday, 11:57:03 (Edited 02.01.2016, Saturday, 12:01:28) »
Дали некој има информација, дали оваа станица може да работи на репетитор (шифт и офсет) ?
Palm Springs commercial photography
    Hot Spots:
        Mini Appearance
        Fashion and Light
        Easy to carry
        14 hours standby, particularly suitable for hotels, KTV
    Feature:
        100% Brand New & Never Used
        PC software programmable
        USB charging
        Connect earphone to RX & TX
        CTCSS/DCS function
        Squelch level
        Channel scan function
        Scrambling function
        Voice Noise Reduction
        Battery Saving
        Busy channel lock-out(BCL)
        Low battery alarm
        Monitor function
        Time-out timer(TOT)
        Voice prompt(English and Chinese)
    Specification:
    Model
TALKCOOP TP-03
    Frequency Range
 UHF:400-470MHz
    Channel capacity
16
    Output power
2W
    Operating Voltage
 DC3.7V
    Antenna Impedance
50ohm
    Working Temperature
 -30°C-+60°C
    Working mode
 Co-channel or dis-channel simplex
    Frequency Spacing
12.5/25KHz
    Color
 Black
    Dimension(Exclude antenna)
86mmX20mmX46mm
    Weight
100g
    Frequency stability
 ±2.5PPM
    Transmitting Current
<1000mA
    Sensitivity
 < 0.16µV(12db SINAD)
    The maximum deviation
 <5KHz
    Spurious Power
 <7.5µw
    Modulation Mode
 F3E
    Audio Power
 >=300mw
    Intermodulation rejection
 50dB
    Receiver Current
 <=100mA
    Squelch sensitivity
<0.2µV
    Squelch standby
20mA
Package Includes
    1 x Portable Radio(Include Antenna and Battery)
    1 x Adaptor
    1 x USB Cable
    1 x Hand Strap
    1 x User's manual
Rodan
   " Working mode:
 Co-channel or dis-channel simplex"
Не ми е до крај јасна реченицава........... да не казува ова нешто? ;)
TeslaBt
Дали некој има информација, дали оваа станица може да работи на репетитор (шифт и офсет).
Јас мислам дека како и да е имаш малку поголеми Baofeng станици шо имат тон поќе функции.
