Author Topic: 5W PLL FM Transmitter  (Read 3170 times)
« Opened on 05.02.2010, Friday, 22:27:55 (Edited 08.02.2010, Monday, 01:56:28) »
Supply voltage 11-13.8 V (stabilised or from a battery)
Supply current up to 1.2 A
Standard frequency range 87.5-107.9 MHz
Audio/MPX input sensitivity 2 V pp (for 75 kHz freq. deviation)
RDS/SCA input sensitivity 0.2 V pp (for 7.5 kHz freq. deviation)
Board dimensions 109 x 54 mm
Part list
Q1 - BF240
Q2 - BFG135 (BFG235)
Q3 - 2SC1971 (2N3553) + heatsink
Q4 - BC547B
D1 - SB260 (1N5822, 1N581x)
D2, D3 - BBY40 (BBY31)
D4 - LED 5mm
U1 - 78L09
U2 - TSA5511 (TSA5512, SDA3202) in DIL socket
U3 - PIC16F627A in DIL socket (programmed)
U4 - 78L05
R1, R2, R11, R17, R20 - 10k
R3, R21 - 270R
R4, R15 - 33k
R5, R7, R12, R13, R16 - 680R
R6, R14 - 18k
R8 - 47R (33R if Q2 is BFG235)
R9 - 18R
R10 - 4k7
R18 - 3k3
R19 - 100k smd 1206
R22 - 91R
R23 - trimmer 5k mini
C1, C4, C9, C12, C13, C14, C15, C30, C31, C32, C33, C35 - 10n smd 1206 (C)
C2, C17, C20 - 15p (C)
C3 - 10p (C) (15p if the PCB is single-sided)
C5 - 1n (C)
C6, C28, C29, C34 - 100u/10V (E)
C7, C26 - 10u/35V (E)
C8 - 22p (C)
C10 - 47p (C) (33p if Q3 is 2N3553)
C11, C27 - 100n (C)
C16, C36 - 33p (C)
C18 - trimmer 50p
C19 - 470u/16V (E)
C21 - 4u7/50V (E)
C22 - 330p (C)
C23, C24 - 47p (C)
C25 - 3n3 (P)
L1 - 3.5 turns on 7 mm diameter
L2 - 1uH/815mA choke, or about 10 turns of thin wire on mini ferrite core
L3 - 2.5 turns on 6 mm diameter (4.5 turns if Q3 is 2N3553)
L4, L5 - 3.5 turns on 6 mm diameter
Y1 - crystal 6.4 MHz or 3.2 MHz
TR1 - rf ferrite transformer 2:1 (3:1 if Q3 is 2N3553), see text
SW1, SW2 - button mini
J1, J2, J3 - BNC connector 90 deg.
J4 - power supply connector
J5 - HD44780 LCD standard connector, 2x8 or 2x16 characters
J6, J7 - jumper
http://pira.cz/entx4.htm
http://pira.cz/plltsa.zip
Offline Cyberking
Одг: 5W PLL FM Transmitter
« Reply #1 on 06.02.2010, Saturday, 00:28:00 »
Добар вака изгледа ...само не пишува ништо околу елементите...
« Reply #2 on 06.02.2010, Saturday, 00:46:58 (Edited 06.02.2010, Saturday, 00:51:25) »
ги има на линкот кој го зададов но еве сега ги пастирав и на форумот ;)
Offline Cyberking
« Reply #3 on 06.02.2010, Saturday, 10:59:48 »
Дали деловиве може да се најдат лесно ...ме интересира посебно за дисплејот...
« Reply #4 on 06.02.2010, Saturday, 15:34:26 »
може да се најде дисплејот 2х16
Offline Goce
« Reply #5 on 06.02.2010, Saturday, 16:38:38 »
Овој што е на сликава е 2x8 може и таков да се најде.
« Reply #6 on 06.02.2010, Saturday, 19:03:23 »
ладилников колку е мал и не е баш за 2SC1971
Offline Cyberking
« Reply #7 on 07.02.2010, Sunday, 01:21:59 »
Ваша препорачка како би бил за правење лесен тежок и дали вреди да се прави ?
« Reply #8 on 07.02.2010, Sunday, 01:34:00 »
мене ми изгледа како едноставен а може и нај едноставен ПЛЛ за правење.
Offline Cyberking
« Reply #9 on 07.02.2010, Sunday, 10:46:56 »
Да не има некој дел што неможе да се најде или тешко се наога ,...и дали ке вади 5W ?
Offline DARK
  • Баниран
« Reply #10 on 28.03.2010, Sunday, 18:17:31 »
за во школо треба да направам проект за ПЛЛ детектор
дали ова е тоа сто барам  ???
или во некоја друга тема има за плл детектор(детектор на  FM-сигнали) ако има може да ставте линк
или ако знаете нешто во врска со него или некоја страна со него да ставите ,тешко се наогја матрејал   :-X
« Reply #11 on 28.03.2010, Sunday, 22:33:29 »
Не е ова баш тоа што ти треба. PLL детектор се користи во дигиталните приемници и се мери отстапувањето на влезниот сигнал од подесената фрекфенција (со PLL склоп) на локалниот осцилатор и притоа се добива напон на „грешка“ кој всушност е аудиото (имаме индиректна детекција).
Offline DARK
  • Баниран
« Reply #12 on 29.03.2010, Monday, 01:11:30 »
ок фала многу
најдов ја несшто  8)
Offline Cyberking
« Reply #13 on 05.04.2010, Monday, 14:55:04 »
Дали се мести дигитално фрекфенцијата на која ке се емитува или механички малку повеке инфо околу тоа
« Reply #14 on 05.04.2010, Monday, 14:58:04 »
се мести дигитално преку тие тастерите
се работи со микроконтролер кој контролира посебно коло за таа намена, немаш механичко ништо освем тастерите на кој треба да прицкаш и да ја промениш ф-та.
