Author Topic: Тестер за зенер диоди со обичен волтметар  (Read 2228 times)
« Opened on 23.01.2012, Monday, 11:38:23 (Edited 04.03.2013, Monday, 04:54:50) »
http://gsuryalss.wordpress.com/2011/02/02/zener-diode-tester/
Above circuit shows a zener diode tester which tests zener diodes with breakdown voltages extending up to 120 volts.This tester Circuit helps user to measure the Zener operation voltage while you can not see the mark on the zener diode .The main advantage of this circuit is that it works with a voltage as low as 6V DC and consumes less than 8 mA current. The circuit can be fitted in a 9V battery box. Two-third of the box may be used for four 1.5V batteries and the remaining one-third is sufficient for accommodating this circuit. In this circuit a commonly available transformer with 230V AC primary to 9-0-9V, 500mA secondary is used in reverse to achieve higher AC voltage across 230V AC terminals. Transistor T1 (BC547) is configured as an oscillator and driver to obtain required AC voltage across transformers 230V AC terminals. This AC voltage is converted to DC by diode D1 and filter capacitor C2 and is used to test the zener diodes. R3 is used as a seri- es current limiting resistor. After assembling the circuit, check DC voltage across points A and B without connecting any zener diode. Now switch on S1. The DC voltage across A-B should vary from 10V to 120V by adjusting potmeter VR1 (10k). If every thing is all right, the circuit is ready for use. For testing a zener diode of unknown value, connect it across points A and B with cathode towards A. Adjust potmeter VR1 so as to obtain the maximum DC voltage across A and B. Note down this zener value corresponding to DC voltage reading on the digital multimeter. When testing zener diode of value less than 3.3V, the meter shows less voltage instead of the actual zener value. However, correct reading is obtained for zener diodes of value above 5.8V with a tolerance of  10per cent. In case zener diode shorts, the multimeter shows 0 volts
Бицикле ,барем два реда да напишеше и објаснеше  во што е поентата на написов.Има помлади и нови членови кои и не знаат за што се работи.
Иако има на англиски некое објаснување, редот ни е да слушаме постари :)
Зенер диодите се слични како и обичните, само што имаат повиско праг на проводнос, односно обичните диоди имаат праг на проводливост најчесто од 0.7в додека зенерките имаат повисок напон на спроведување, односно до напонот на кој се декларирани(3.6 7.2 9 14.4 итн.) Обичните мултиметари  можат да испитаат само диоди со низок напон, бидејќи пуштаат низок напон. За да можете да проверите зенер диода потребен е посебен уред , како дадениот. Уредот е генератор на висок напон, така што може да ги задоволи потребите за повеќето диоди. Имено, кога ќе ја ставите диодата, таа го ограничува напонот на оној напон на кој што е декларирана диодата, и на инструментот треба да се појави приближно ист напон. Бидејќи стујата која минува низ зенер-дидата е ограничена со R3, овој уред е безбеден за употреба и нема да ја прегори зенер-диодата.
ааах...мислам дека си грешка...напонот на проводност на зенер диодите е исто 0,7V исто како и напонот на проводност на обичните насочувачки диоди...разликата е во напонот на пробив што кај зенер диодите е многу мал. иначе секоја диода може да стане зенер диода ако се донесе доволно голем инверзен напон...
епа затоа е врзана обратно диодата... на одреден напон настанува зенеров порбој и спроведува... инаку да- секоја диода е зенер-диода, ама тие што се на 500-600в не ги сметаат како зенерки колку што знам...
Па и не е баш така, секоја зенер диода е обична диода дур не се надмине инверзниот напонот на пробив, кога ќе се надмине, обичната диодата гори и е неупотреблива ;). Зенер диодите имаат посебна градба, така да, дури и во моментот кога ќе се достигне инверзниот напон на пробив, диодата не гори ;), напонот на нејзините краеви е константен, без разлика на јачината на струјата што тече низ неа (барем тоеретски, практично, зенер диодите се делат по класи на моќност ;)).
не ли горат од преголема струја што тече низ нив, ти стави зенер диода без отпорник ке ти се спржи и таа...
Па да, или треба да има струјно ограничување со транзистор изведено, или да има отпорник, затоа, на пример, се става зенер диода во базата на транзисторот, за да не може многу голема струја да повлече низ неа транзисторот, а сепак да биде во SAT кога ќе проведе ;).
има за зенерки во теорија повеќе мислам,.,.,. патем R3 е постаен за да ја ограникчи струјата,.
