Author Topic: Метал детектор со 5 дела  (Read 2703 times)
« Opened on 05.11.2011, Saturday, 20:08:23 (Edited 05.11.2011, Saturday, 20:10:03) »
picoDetector : a PIC12 metal detector
извор:
http://www.micro-examples.com/public/microex-navig/doc/076-picodetector.html
сорс кодот
 * picoDetector : an ultra simple and cheap metal detector
 * Author : Bruno Gavand, april 2009
 * see more details on http://www.micro-examples.com/
 * source code for mikroC PRO compiler V1.65
 * feel free to use this code at your own risks
 * target : PIC12, oscillator in HS mode, watchdog enabled
 * PIC PIN Assignemnt :
 * GP0 : detect LED indicator
 * GP1 : calibrate LED indicator
 * GP2 : NC
 * GP3 : NC
 * GP4, GP5 : inductor
#define MAXTRY 15       // number of watchdog restart to calibrate loop counter
unsigned char   ctr ;           // number of loops between two watchdog resets
unsigned char   previous ;      // previous value of ctr
unsigned char   calibr ;        // calibration value when oscillator runs free
unsigned char   restarts ;      // number of watchdog restarts
unsigned char   en ;            // enable flag, allows detection
 * main loop
void    main()
        unsigned char   i ;
         * configure GPIO as digital port
        CMCON0 = 7 ;
        ANSEL = 0 ;
        TRISIO = 0 ;
        GPIO = 0 ;
         * power up ?
        if(STATUS.NOT_TO)
                 * yes, init variables
                restarts = 0 ;
                calibr = 1 ;
         * watchdog reset counter
        if(restarts < 255) restarts++ ;
         * if counter differs too much from calibration value
        if((previous ^ ctr) > calibr)
                 * turn detect LED on
                GPIO.F0 = en ;
                 * if not on power up
                if(STATUS.NOT_TO == 0)
                         * while in calibration mode
                        if(restarts < MAXTRY)
                                 * shift calibration value
                                 * and wait a little bit
                                calibr <<= 1 ;
                                Delay_ms(5) ;
                else
                         * turn detect LED off
                        GPIO.F0 = 0 ;
         * save last counter
        previous = ctr ;
         * is calibration over ?
        if(restarts > MAXTRY)
                 * yes, turn calibrate LED off
                 * and set enable flag
                GPIO.F1 = 0 ;
                en = 1 ;
        else
                 * no, turn calibrate LED on
                 * and clear enable flag
                GPIO.F1 = 1 ;
                en = 0 ;
         * set watchdog prescaler
        OPTION_REG = 0b11111001 ;
         * start counter, to be interrupted by watchdog
        ctr = 0 ;
        for(;;)
               ctr++ ;
Одг: Метал детектор со 5 дела
« Reply #1 on 05.11.2011, Saturday, 21:58:19 »
Дали на некој му е јасно како работи овој детектор? Не верувам да е на принцип напраќање на радио сигнал кој се одбива од металот па се враќа назад и се прима во намотката, бидејки тоа е сложено за овој прост уред
« Reply #2 on 05.11.2011, Saturday, 22:08:11 »
работи на принцип на промена на фреквенцијата
имаш некој глуп LC осцилатор кој осцилира на одредена фреквенција
калемот кога нема метал до него осцилира на некоја фиксна фреквенција (ок со некој мали отстапувања) пр. 1кХз, кога ќе се доближи метал до калемот се променува индуктивноста со што се менува и фреквенцијата на која осцилира пр. паднала на 700Хз (ова се од памет некој глупи вредности)
програмата е така напишана да ја проверува фреквенцијата цело време, ако отстапи од таа која што е на почетокот калибрирана се уклучува лед диодата
« Reply #3 on 05.11.2011, Saturday, 22:51:45 »
епа значи дека ако калемот е помалце или повеке uH ке свети цело време ЛЕДот бидејки фрекфенцијата нема да се софпаѓа со таа зададена во софтверот
« Reply #4 on 05.11.2011, Saturday, 22:56:39 »
па имаш од 10 до 330µH можност во тие граници да ставиш некој, пошто откако ќе го ставиш калемот и ќе го уклучиш ова, тоа се калибрира на таа вредност од калемот, ако го смениш калемот и го уклучиш повторно тоа ќе си се подеси по новата вредност
но доколку не е исклучено и доближиш некој метал што ќе ја промени работната фреквенција ќе се активира лед диодата
« Reply #5 on 05.11.2011, Saturday, 23:04:18 »
Фала за одговорите, само штета што го избрале овој микроконтролер, да беше 12F675 ке пробав да ја направам шемата.
« Reply #6 on 05.11.2011, Saturday, 23:07:37 »
Mислам дека е доста сличен со 675,пробај направи го со него...
« Reply #7 on 05.11.2011, Saturday, 23:09:38 »
највероватно неможе, бидејки треба да се преработи кодот за тој микроконтролер.
« Reply #8 on 05.11.2011, Saturday, 23:12:45 »
Мислам дека ќе запали,истиот е само што овој има поголема меморија и +уште некој додаток...Ако го збере хексот во 675-ката би требало да проработи...
П.С баш сега збирам делови,па ќе го правам.
« Reply #9 on 05.11.2011, Saturday, 23:15:35 »
види, самиов сорс е универзален но при правење на хексот е избран 683 а не 675, така да треба да се стави тој сорс во програмот и да се направи за 675.
Фајлот ке го збере без проблем бидејки е мал.
« Reply #10 on 05.11.2011, Saturday, 23:15:47 »
P12F629 и P12F675 се скоро исти и можат да се заменуваат односно 675 може да се стави на место на 629 но незнам дали може обратно
а овај што е не би можел сегде да се става како замена за овие, или пак некој од овие да се стави за негова замена
пробај глупа е рограмата можеби ќе работи
« Reply #11 on 05.11.2011, Saturday, 23:18:58 »
До која длабочина може ова да бара?? Или само за експериментирње е ?
« Reply #12 on 05.11.2011, Saturday, 23:19:46 »
Премногу усложнување на проста работа !! Направете еден прост осцилатор кој ке емитува околу 455 Кхз ,земете еден СТ приемник(популарен транзистор!) и ке имате подобра осетливост и домет од овој склоп ;D ;D
« Reply #13 on 05.11.2011, Saturday, 23:22:00 »
а нели треба да се стави сорсот во mikroC PRO compiler и да се експортира за 675 или може и вака?
« Reply #14 on 05.11.2011, Saturday, 23:58:20 »
пробај, можеби и вака ќе работи
а може и да направиш и како што рече да се изготви нов хекс фајл за новиот микроконтролер, баш ќе знаеш дали ќе работи или не
пошто ако има некој различен порт или различно нагодување ќе ти извади ерор компајлерот :)
