Author Topic: Eлектронски осигурач  (Read 1206 times)
« Opened on 23.04.2011, Saturday, 11:54:20 (Edited 25.08.2013, Sunday, 06:40:25) »
Еве една шема за електронски осигурач до 2A и напон до 230V.Исто така има регулација на струјата од 0,3А до 2А ;D.
Шемата:
When the current through the load exceeds a level determined by the position of the wiper on the 1k wire-wound pot, this circuit cuts off the load immediately. If S1 is open, the range is approximately 300-650 mA, and 0.8-2A when it is closed.
The key variable in the operation of the fuse is the voltage drop across the power resistor(s) which are connected in series with the load. This voltage drop is directly proportional to the current the load draws. When this current is low, the voltage across the resistors is also small and cannot trigger T1. At the same time the gate of T2 is fed from a little power supply built around a negative voltage regulator. T2 is conducting and the load is on.
If the current through the load then gets too high, so that the voltage created across the resistor(s) can trigger the gate of T1 through the 330R resistor and the pot: T1 starts to conduct, swiftly taking away all the current from the gate of T2. The voltage drop across T1 (MT1-MT2) will then be only 0.7 V and T2 will be firmly off. T1 stays this way all until the momentary (normally closed, "push-to-break") Reset push-button is pressed: this causes the current through T1 to drop below the hold level and forces this triac to turn off. Releasing the Reset button re-enables the current flow to and through the gate of T2, switching it on.
T1 must be a TIC225M, as this particular type has a very low trigger current. T2 is a snubberless BTA12-600CW which cannot be replaced with a 'normal' triac, but maybe with a BTA12-600BW which also can be used without a snubber circuit, but has a little less sensitive gate (not a problem in this design). If the gates of snubberless triacs are DC-controlled and they are switching AC, the DC to control the gates MUST be negative - flowing from the gate, hence the negative voltage regulator. (Snubberless is in fact a registered trade mark belonging to ST.)
The output AC voltage will be 1-5 volts below the input level, depending on the load. Varistors are 250V AC. Pay attention to the "reverse" polarities of the electrolytic capacitor and the diodes before the 7906.
Извор:
http://www.zen22142.zen.co.uk/Circuits/Power/fuse.htm
Одг: Eлектронски осигурач
« Reply #1 on 23.04.2011, Saturday, 16:09:21 »
Јас го имам направено одамна(2-3 години) овој осигурувач,ама не испадна многу добар.Премногу е осетлив,а некојпат знае краткотрајните напонски шпицеви да ги изреагира и да те *сецне* кога најмалку очекуваш! ;D
« Reply #2 on 23.04.2011, Saturday, 16:23:33 »
Можеби може да се среди тоа со мрежен филтер (едно LC коло), како што има во компјутерските напојувања ;).
« Reply #3 on 23.04.2011, Saturday, 16:32:38 »
А го има ли кај нас овој жичаниот потенциометар и колку пари е?
« Reply #4 on 23.04.2011, Saturday, 16:33:15 (Edited 24.04.2011, Sunday, 13:03:29) »
Пробано,ама тука не важи! Врската е чудна и мислам дека овој склоп со трафото и 6 В напојување  е извор на сите *чуда*! Сепак,да не кудам многу ,ако некој сака нека проба.
« Reply #5 on 23.04.2011, Saturday, 16:45:41 »
Па би требало да го има, а колку пари би бил, не знам :S. Не би бил евтин во секој случај :S (моја лична проценка, околу 200 денари :S).
« Reply #6 on 23.04.2011, Saturday, 19:57:40 »
Мислиш на EMI филтер?
Знам ние имавме ваков жичан пот. во школо,по физика.Само доста голем беше потенциометарот,и не верувам дека е ефтин да се купи...Според мене испод 200ден не е. :)
« Reply #7 on 23.04.2011, Saturday, 20:51:00 »
Не не, мислам дека EMI филтри ги викаат оние перманентнине магнети што ги ставаат на каблите, не таков. Мислев баш на LC коло (некогаш може да има и само кондензатор, за да се скрати на делови) во влезниот степен на на напојувањето ;).
« Reply #8 on 23.04.2011, Saturday, 20:53:48 »
E aj види ;D
http://www.google.com/search?hl=en&q=EMI+filter&bav=on.2,or.r_gc.r_pw.&um=1&ie=UTF-8&tbm=isch&source=og&sa=N&tab=wi&biw=1280&bih=891Иначе се разбираме ;D,знам за кои филтер збориш...Ги има исто во овие ЦРТ мониторите...
« Reply #9 on 24.04.2011, Sunday, 15:45:27 »
E aj види ;D
Да, на ова мислев, изгледа сум згрешил ;). Барем да знам како се викаат ;D.
« Reply #10 on 25.04.2011, Monday, 11:31:46 »
интересна шема, вероватно овие компоненти ги има во тие автоматските осигурачи (склопки)
« Reply #11 on 25.04.2011, Monday, 12:45:45 »
ааах тие склопки се даааалеку од ова....таму се ти е електро механика...
