Author Topic: Кабел за дијагностика на возила  (Read 3950 times)
Offline VLATKO*
Fiat Tipo 1.6 75HP број на мотор 835C1  а на ECU-то пишува BOSCH 0 261 200 721
Одг: Кабел за дијагностика на возила
« Reply #16 on 19.03.2011, Saturday, 13:20:26 (Edited 19.03.2011, Saturday, 17:03:03) »
Вакво нешто  :D
http://www.tootoo.com/s-ps/bosch-injector-injector-auto-parts--p-1478980.html ?
Offline dr-mr
« Reply #17 on 19.03.2011, Saturday, 15:36:12 (Edited 19.03.2011, Saturday, 17:03:25) »
тука фо има конекторот за фиат и како да си го направиш интерфејсот
http://pinoutsguide.com/CarElectronics/fiat_car_obd_ii_pinout.shtml
Сепак се ВРТИ !!!
Kаква кола,кој модел е??! Ако имаш можност сликај го конекторот,ке го најдеме во купот..
Offline VLATKO*
« Reply #19 on 04.04.2011, Monday, 21:27:50 (Edited 04.04.2011, Monday, 22:00:10) »
сега ке го сликам,мислам дека е со 3 пина
Споено мислење: 04.04.2011, Monday, 22:00:10
сликав ама ништо не се гледа,еве и една од интернет што ја најдов
Мислам дека ова ќе ти помогне ;).
http://www.fiatforum.com/lets-talk-fiat/98934-making-obd-fiat-connector.html
Прочитај го вториот post ;).
you obviously havent seen the millions of threads i've written about using a few bits of wire to get a 3 pin connector on your car working with an obd connector on a reader. its very easy, and free!
you need 4 lengths of wire. use 3 lengths of wire to connect the 3 pin connector to the obd connector. also use 1 length of wire for power to code reader.
on the 16 pin obd2 connector use the following pins
4- chassis ground (connect to ground on 3 pin connector, or any good chassis earth)
5- signal ground (connect to black wire pin on 3 pin connector)
7- k line (connect to white wire pin on 3 pin connector)
16- 12vDC (connect to battery positive terminal)
you need to remember that there are several 3 pin connectors. the main one is on the front of the fuse box cover in the engine bay.
you could very easily wire a obd connector permanently onto your car (only 4 wires), but you'd need to do at least 3 connectors to cover all modules since there are at least 3 connectors on your car and you cant wire them all into one obd connector safely.
personally i think its better to use 4 lengths of wire and the fiat 3 pin connectors.
