Author Topic: Халогена светилка контролирана преку Радио-контрола на 73 MHz  (Read 815 times)
« Opened on 23.12.2010, Thursday, 14:29:50 (Edited 26.08.2013, Monday, 01:01:52) »
Доста едноставна, а пред се интересна шема. Само ако купувате трафо тоа нема да биде како на шемата за 120V туку за 220V. Се надевам дека нема да ги палите и гасите уличните сијалици кога нетреба :)
Втората слика ако не ви се познава добро, симнете ја и отворете ја и ке се види во сите детали.
This circuit is a 73 MHz Hallogene Lamp Radio-Controlled. The purpose of it is to control the power state of a hallogene lamp by a remote control. When we press the push botton of the remonte control, the power state of the lamp will be changed, so, if the lamp was turned on, it will turned off and if it was turned on, it will turned off. If we press to the button another time, the same action will be occured. When the button is pressed, a LED indicator lights on the remote control.
The system is consisted by two separate circuit. One is the remote control, or the emmetor. The other is the receptor, or the hallogene lamp controller. We plug the input of the lamp controller circuit to the 120VAC source of the sector to supply it. The lamp must be pluged to the output of the circuit to be supplied and controlled.
The controller circuit has also an antenna to receive the signal of the remote control. The remote control has also an antenna to transmit the signal to the controller circuit and have to be powered by a 9V battery. Two things important for my circuit are not mentioned in the schematic. There are about the two logic component.
The first one is the Schmitt trigger NOT gate (74LS14). Its Vcc pin must be connected to the output of the +5V regulator (7805). And its GND pin must be connected to the ground of the circuit. The second one is the JK Flip-Flop (74LS76). Its Vcc pin must be connected to the output of the +5V regulator (7805). And its GND pin must be connected to the ground of the circuit.
извор:
http://www.diy-electronic-projects.com/p178-73-MHz-Hallogene-Lamp-Radio-Controlled
Е, вака треба да се post-ираат шеми, детално убаво објаснето, од каде е шемата, што како, сликите не се преголеми, смалени се, upload-ирани се на перманентно место (т.е. hosting-ов на форумов) така да секогаш можете да ги најдете, да се предупреди за некои битни разлики меѓу некој странски и наш стандард, итн.
Извинете за off-topic дискусија, но морав да пишам, искрено, не знам од кога немам видено ваков post. Не го прочитав цел, но ако некогаш ми притреба нешто вакво да правам, знам дека скоро се што ми треба ќе најдам уште во првиот post. А не да се бара низ цела тема за да сенајдат вредности на компоненти, PCB и не знам уште што :S.
Се слагам Гига ВАт со тебе, убаво објаснето - + за човекот и неговиот труд!
Благодарам GW и Batka за пофалните зборови, реп+ :)
