Author Topic: 4W ФМ предавател  (Read 1656 times)
4W ФМ предавател
« Opened on 21.11.2009, Saturday, 00:07:23 (Edited 26.03.2010, Friday, 19:35:42) »
Шемава ја најдов на линков:
http://www.elecfree.com/circuit/radio_frequency/fm-transmitter-4w-by-2n3553
Ако некој ја правел ке ја препознае. Ако вистина вади 4W тогаш вреди да се направи.
FM Transmitter 4W by 2N3553
This is a small but quite powerful FM transmitter having three RF stages incorporating an audio preamplifier for better modulation. t has an output power of 4 Watts and works off 12-18 VDC which makes it easily portable. It is the ideal project for the beginner who wishes to get started in the fascinating world of FM broadcasting and wants a good basic circuit to experiment with.
Technical Specifications - Characteristics
Modulation type: ........ FM
Frequency range: .... 88-108 MHz
Working voltage: ..... 12-18 VDC
Maximum current: ....... 450 mA
Output power: ............ 4 W
Parts List
R1 = 220K
R2 = 4,7K
R3 = R4 = 10K
R5 = 82 Ohm
R = 150Ohm 1/2W x2 *
VR1 = 22K trimmer
C1 = C2 = 4,7uF 25V electrolytic
C3 = C13 = 4,7nF ceramic
C4 = C14 = 1nF ceramic
C5 = C6 = 470pF ceramic
C7 = 11pF ceramic
C8 = 3-10pF trimmer
C9 = C12 = 7-35pF trimmer
C10 = C11 = 10-60pF trimmer
C15 = 4-20pF trimmer
C16 = 22nF ceramic *
L1 = 4 turns of silver coated wire at 5,5mm diameter
L2 = 6 turns of silver coated wire at 5,5mm diameter
L3 = 3 turns of silver coated wire at 5,5mm diameter
L4 = printed on PCB
L5 = 5 turns of silver coated wire at 7,5mm diameter
RFC1=RFC2=RFC3= VK200 RFC tsok
TR1 = TR2 = 2N2219 NPN
TR3 = 2N3553 NPN
TR4 = BC547/BC548 NPN
D1 = 1N4148 diode *
MIC = crystal microphone
Одг: 4W ФМ предавател
« Reply #1 on 21.11.2009, Saturday, 00:34:23 »
L4=?  :'(
« Reply #2 on 25.11.2009, Wednesday, 01:49:40 »
Еве ја шемата но е со хирогливски букви напишана и не се разбира, но тамо пише колку треба да е таа
намотка.
http://www.electronics-lab.com/projects/rf/001/fm2.gif
« Reply #3 on 25.11.2009, Wednesday, 13:50:38 »
Хаха, знаеш што пишува за L4?? Дека веќе е на плочката :D
« Reply #4 on 25.11.2009, Wednesday, 14:17:51 »
леле  >:( >:( >:( ја се помешав со L2 кога ја видов сликата
« Reply #5 on 14.12.2009, Monday, 00:14:39 »
Дечки да не знае некој колкава треба да биде плочкава, колку на колку cm ?
http://www.electronics-lab.com/projects/rf/001/index.html
« Reply #6 on 14.12.2009, Monday, 21:17:38 »
Вака: Ако еден транзистор е точно 9mm тогаш плочката е: 12см х 3.5см
« Reply #7 on 14.12.2009, Monday, 22:49:38 »
можно е, него тоа што се чидевме за едната намотка каде е :) пишуваше дека е на плочката ама не можевме да ја видиме. Намотката е уствари само 1 круг  :) на самата плоча..
Што мислиш, од око дали може овој предавател да извади 4W?
« Reply #8 on 15.12.2009, Tuesday, 20:01:38 »
Повеќе мислам дека ќе извади максимум 2W.
« Reply #9 on 15.12.2009, Tuesday, 20:23:58 (Edited 16.12.2009, Wednesday, 13:57:00) »
Па и не е така лошо 2W  ;)
еве слика
Offline Cyberking
« Reply #10 on 11.03.2010, Thursday, 15:09:33 »
Шема за плочкава таа горе точна е?...и дали ке може да се приклучи на компјтуер ?
« Reply #11 on 11.03.2010, Thursday, 18:18:13 »
Точна. Може да се приклучи на компјутер преку Winamp да го наместиш Equalizer-от убаво и ќе имаш добар звук.
доказ дека шемата е исправна
« Reply #12 on 11.05.2010, Tuesday, 01:11:55 (Edited 06.01.2021, Wednesday, 22:10:24) »
