Author Topic: 2x100w засилувач со излезни транзистори 2SC 5200 - ПОМОШ  (Read 28358 times)
Батка со ова може да се испитаат големите мосфет транзистори од појачалото - 2SC 5200 ???
Не може,тоа е наменето за NPN и PNP транзитори,а не за GDS. ;) :)
На форум има само за тие тип транзисторите како да ги испитам а за овие големиве 2SC5200 може некако со унимер да се испитаат ???
Ѕирни тука,ваљда ќе се снајдеш...
http://www.4qdtec.com/mostest.html
Споено мислење: 27.11.2010, Saturday, 15:07:38
Еве нешто друго што најдов на нет...се ќе најдеш,само треба да пробаш!Google е за тоа! ;)
Testing MOSFETs
Field Effect Transistors are difficult to test with a multimeter, but "fortunately" when a power MosFet blows, it blows big time: all their leads will show in short circuit. 99% of bad MosFets will have GS, GD and DS shorted. In other words - everything will be connected together.
Note: When measuring a MosFet hold it by the case or the tab and don't touch the metal parts of the test probes with any of the other MosFet's terminals until needed. Do not allow a MosFet to come in contact with your clothes, plastic, etc. because of the high static voltages they can generate.
You'll know a MosFet is good when the Gate has infinite resistance to both Drain and Source. Exceptions to this rule are FETs with protection circuitry - they may act like there is a diode shunting GS - a diode drop for gate reverse bias. Connecting Gate to Source should cause the Drain to Source act like a diode. Forward biasing GS with 5V and measuring DS in forward bias should yield very low ohms. In reverse bias, it will still act like a diode.
Another simple test procedure: connect the multimeter's negative lead to the source of the MosFet. Touch the MosFet's Gate with the meter's positive lead. Move the positive probe to the Drain - you should get a low reading as the MosFet's internal capacitance on the Gate has now been charged up by the meter and the device is turned-on. With the meter's positive lead still connected to the Drain, touch the source and gate with your finger. The Gate will be discharged through your finger and the reading should go high, indicating a non-conductive device! This simple test is not fail proof, but it's usually adequate.
значи...не постои вид на транзистори што се ТИП, постојат биполарни и униполарни транзистори. Биполарни транзистори се NPN и PNP транзистори, униполарни се MOSFET-P, MOSFET-N. ТИП е серија од танзистори како што се BC(547) BD(135) и има TIP(21). Транзисотрите ти што ги имаш  2SC5200 се НПН транзисори што значи дека можеш да и испитуваш како што се испитуваат НПН транзистори, независно дали се некои СМД, дали се во TO3, TO220 куќиште (или какво и да е куќиште, мал милион ги има). Само треба да знаеш кое е база, кое е емитер, кое е колектор. во случај да незнаеш еве ти даташит..
http://www.datasheetcatalog.org/datasheet/toshiba/3228.pdf
и ај сликни ја плочката одоздола и од горе да ја видиме како е направена...
Еве слики одоздола колега  ;)
Offline DARK
  • Баниран
аа ова од кога ти ја прелемив јас  ;D
Еве една шема за тестирање мос фет-ови.Ако е се во ред ЛЕД треба да трепка  ;D
Направена е оооодамна и заборавена..... ;)
Батка јас ги измерив моиве мосфетови и излезе дека двата мосфета од едниот канал се изгорени т.е. на унимерот кога мерев на сите пинови покажува 001  ;) Не се исправни така ?
Па направи го тестерот и провери  :D ;)
Колеги го најдов дефектот со вујко ми  ;) Он е електроничар и долга приказна е тоа  :D ...
Да се вратиме на темата ... Биле изгорени излезните мосфет транзистори и големите керамички отпорници, ги сменив , појачалото работи ама многу брзо загреваат драјверите за излезните транзистори( TIP 41C TIP 42C )Ги измерив со професорот и тие се во ред ама загреваат одма .. Што може да биде проблемот ??? ...
Стави ги на исто ладилно тело со излезните транзистори, така ќе има температурна стабилизација на колото ;).
Ќе има термичка спрега ;D
Ама пред тоа не грееја така  одма  :-\ А и едниот канал крчи малце  :-\
Па нели воопшто не ти работел пред тоа ;D.
