Кратко објаснување:
16 Track Live Step and Morph Sequencer + advanced Arpeggiator
Слика:
Карактеристики:
* optimized for live playing and editing
* intuitive user interface with flat menu hierarchy, wide screen display (2*2x40=160 characters) and 16+1 rotary encoders with menu page dependent "soft function".
* multiple MIDI Out ports (up to 10) for reduced MIDI latency
* 2 MIDI In ports (e.g. for separated MIDI clock and MIDI keyboard input)
* USB interface which supports USB MIDI protocol to send events more than 100 times faster
* every parameter can be modified in realtime w/o affecting the sequencer timings
* one sequencer pattern consists of 4 independent tracks
* four patterns can be played at the same time -> makes 16 tracks
* each track consists of up to 16 layers which can be assigned to various parameters (e.g. Note/Velcity/Gatelength/Chords/CC/PitchBender/Delay/Probability/Roll)
* Transpose and Arpeggiator function
* Force-to-Scale function with 166 predefined scales
* Track directions: Forward/Backward/PingPong/Pendulum/Random Dir/Random Step
* Track direction progressive parameters (Step Forward, Jump Back, Repeat, Interval, Skip, Repeat)
* free adjustable clock divider for each track. Supported timebases 1..256, normal and tripled
* available length for every track: 1-256 steps
* with 384ppqn resolution, 256th notes can be played
* loop point within track
* step events can be triggered multiple times (up to 4 times per step) with a delay value of 1-31 to realize drumrolls, ratterbeats, flams...
* 8 trigger layers for Gate/Skip/Accent/Glide/Roll/Random Gate/Random Value/No Fx
* various Groove styles (shuffle/inverted shuffle/...) + customizable Groove Templates (Delay/Length/Velocity)
* Humanizer function (random modification of note/velocity/gatelength)
* Pattern Morphing, controllable in 128 steps with a Modulation Wheel
* Echo Fx with Repeat/Delay/Feedback/Note increment/Gatelength/Delay parameters
* LFO Fx with different waveforms, synchronized period length, adjustable reset point, phase, OneShot mode. Assignable to Note/Velocity/Length/CC
* Note Limiter Fx
* Manual step triggering
* Step and Realtime Record function
* Copy/Paste/Clear function
* Scroll and Step Move function
* Random pattern generator
* Undo function
* parameters of multiple steps can be changed relatively and absolutely with a single rotary encoder
* parameters of multiple tracks can be changed the same time with a single rotary encoder
* Tracks and parameter layers can be muted
* Accent/Slide/CC sequences
* inbuilt MIDI mixer/controller with 128 free definable mixer maps
* inbuilt MIDI router
* virtual "Loopback port" for Master/Slave tracks
* split function for Transposer/Arpeggiator
* 8 optional CV outputs and gates for analog gear
* CV outputs can also be accessed from MIDI In (-> replaces a CV interface)
* 64 optional 1 mS drum trigger outputs
* 8*128 patterns are stored on SD Card
* 128 mixer maps are stored on SD Card
* pattern sets can be looped and chained in song mode
* phrase mode which allows to switch between the 16 predefined pattern sets (for fills/breaks/chorus, etc...)
* pattern switching can be synchronized to the measure
* MIDI Remote functions
* 2.5-300 BPM (MIDI clock master)
* external sync (MIDI clock slave)
* DIN sync output for controlling vintage sequencers
* works with 16x MIDI clock resolution (384 ppqn)
* several hardware options (e.g. a 64 Button/Duo-LED matrix)
* details and demo samples in the User Manual
* DIY ONLY!!! (commercial release neither planned, nor allowed!)
Кој има пари и муда да го изгради еве линк до целиот проект каде има целосна документација:
http://www.ucapps.de/midibox_seq.html
http://ucapps.de/midibox_seq_manual.html
