Author Topic: MIDIbox SEQ V4 - Секвенцер  (Read 1770 times)
Offline nCounTr
  • Почивај во мир
  • Дипл.Ел.Инж.
« Opened on 03.05.2010, Monday, 21:47:23 (Edited 03.05.2010, Monday, 21:51:41) »
Кратко објаснување:
16 Track Live Step and Morph Sequencer + advanced Arpeggiator
Слика:
Карактеристики:
   * optimized for live playing and editing
   * intuitive user interface with flat menu hierarchy, wide screen display (2*2x40=160 characters) and 16+1 rotary encoders with menu page dependent "soft function".
   * multiple MIDI Out ports (up to 10) for reduced MIDI latency
   * 2 MIDI In ports (e.g. for separated MIDI clock and MIDI keyboard input)
   * USB interface which supports USB MIDI protocol to send events more than 100 times faster
   * every parameter can be modified in realtime w/o affecting the sequencer timings
   * one sequencer pattern consists of 4 independent tracks
   * four patterns can be played at the same time -> makes 16 tracks
   * each track consists of up to 16 layers which can be assigned to various parameters (e.g. Note/Velcity/Gatelength/Chords/CC/PitchBender/Delay/Probability/Roll)
   * Transpose and Arpeggiator function
   * Force-to-Scale function with 166 predefined scales
   * Track directions: Forward/Backward/PingPong/Pendulum/Random Dir/Random Step
   * Track direction progressive parameters (Step Forward, Jump Back, Repeat, Interval, Skip, Repeat)
   * free adjustable clock divider for each track. Supported timebases 1..256, normal and tripled
   * available length for every track: 1-256 steps
   * with 384ppqn resolution, 256th notes can be played
   * loop point within track
   * step events can be triggered multiple times (up to 4 times per step) with a delay value of 1-31 to realize drumrolls, ratterbeats, flams...
   * 8 trigger layers for Gate/Skip/Accent/Glide/Roll/Random Gate/Random Value/No Fx
   * various Groove styles (shuffle/inverted shuffle/...) + customizable Groove Templates (Delay/Length/Velocity)
   * Humanizer function (random modification of note/velocity/gatelength)
   * Pattern Morphing, controllable in 128 steps with a Modulation Wheel
   * Echo Fx with Repeat/Delay/Feedback/Note increment/Gatelength/Delay parameters
   * LFO Fx with different waveforms, synchronized period length, adjustable reset point, phase, OneShot mode. Assignable to Note/Velocity/Length/CC
   * Note Limiter Fx
   * Manual step triggering
   * Step and Realtime Record function
   * Copy/Paste/Clear function
   * Scroll and Step Move function
   * Random pattern generator
   * Undo function
   * parameters of multiple steps can be changed relatively and absolutely with a single rotary encoder
   * parameters of multiple tracks can be changed the same time with a single rotary encoder
   * Tracks and parameter layers can be muted
   * Accent/Slide/CC sequences
   * inbuilt MIDI mixer/controller with 128 free definable mixer maps
   * inbuilt MIDI router
   * virtual "Loopback port" for Master/Slave tracks
   * split function for Transposer/Arpeggiator
   * 8 optional CV outputs and gates for analog gear
   * CV outputs can also be accessed from MIDI In (-> replaces a CV interface)
   * 64 optional 1 mS drum trigger outputs
   * 8*128 patterns are stored on SD Card
   * 128 mixer maps are stored on SD Card
   * pattern sets can be looped and chained in song mode
   * phrase mode which allows to switch between the 16 predefined pattern sets (for fills/breaks/chorus, etc...)
   * pattern switching can be synchronized to the measure
   * MIDI Remote functions
   * 2.5-300 BPM (MIDI clock master)
   * external sync (MIDI clock slave)
   * DIN sync output for controlling vintage sequencers
   * works with 16x MIDI clock resolution (384 ppqn)
   * several hardware options (e.g. a 64 Button/Duo-LED matrix)
   * details and demo samples in the User Manual
   * DIY ONLY!!! (commercial release neither planned, nor allowed!)
Кој има пари и муда да го изгради еве линк до целиот проект каде има целосна документација:
http://www.ucapps.de/midibox_seq.html
http://ucapps.de/midibox_seq_manual.html
АМАН ЧИТАЈТЕ ПРАВИЛA
Одг: MIDIbox SEQ V4 - Секвенцер
« Reply #1 on 03.05.2010, Monday, 22:21:38 »
Кога сме веќе кај MIDI базирани периферии: Дали некој начекал USB-to-MIDI кабел, каде и колку пари???
« Reply #2 on 29.08.2010, Sunday, 01:26:02 »
ако може ќе се собереме и ќе го убедиме наставникот во народна техника да го правиме овој проект (секвенцер) па ако е за пари нема проблем!
П.С. Имаме муда,ќе собереме цела табла за јајца ;D ;D ;D
[/glow]Извинете за речник!!
« Reply #3 on 29.08.2010, Sunday, 02:19:31 »
ХАХАХАХАХА ЗАКОН!!!!! цела табла јајца EPIC!!!
Offline alex
« Reply #4 on 29.08.2010, Sunday, 04:30:55 »
од логинг за 1200 или 1220  денари го купив (Plug`n`play) а имаш и поквалитетен од M-Audio за 2 и нешто иљадарчиња во артист
« Reply #5 on 29.08.2010, Sunday, 16:44:14 »
Ова е супер информација за кабелот! Фала alex :)
