Author Topic: Интегрирани кола - ваша колекција  (Read 3141 times)
« Opened on 11.04.2010, Sunday, 20:48:52 (Edited 11.04.2010, Sunday, 21:34:53) »
Значи самото име кажува
какви имате колку имате
од каде ви се и тн.
Исто така доколку некој сака да се размени слободно нека пише тука
Offline Aleks
MC6809P 8-Bit Microprocessing Unit
MC6821CS PERIPHERAL INTERFACE ADAPTER
HM6116LP 2048-word X 8bit High Speed CMOS Static RAM
UM6116-2 2K x 8 High Speed CMOS SRAM
Z8430 NMOS/CMOS Z80 CTC COUNTER/TIMER CIRCUIT
HCF4067BE ANALOG MULTIPLEXER/DEMULTIPLEXER
SN74LS244N OCTAL BUFFERS AND LINE DRIVERS WITH 3-STATE OUTPUTS
TIBPAL16L8-25CN LOW-POWER HIGH-PERFORMANCE IMPACT E PAL CIRCUITS
SN74LS273N OCTAL D FLIP-FLOP WITH CLEAR
DM74LS373N TRI-STATEE Octal D-Type Transparent Latches and Edge-Triggered Flip-Flops
T74LS240B1 Octal Buffer / Line Drivers with 3-State Outputs
T74LS138B1 1 of 8 Decoder / Demultiplexer
CDP1857CE 4-Bit Bus Buffer/Separator, 4-bit CMOS non-inverting bus separator designed
MC75492P Quad LED Segment Driver / Hex LED Digit Driver
HCF4011BE QUAD 2 INPUT NAND GATES
MC1408P8 8-bit D/A converter
MC14076BCP 4-Bit D-Type Register with Three-State Outputs
mmc4001e ???
CD40106BE CMOS Hex Schmitt Trigger
MC14495P1 HEXADECIMAL-TO-SEVEN SEGMENT LATCH/DECODER LED DRIVER
HEF4013BP Dual D-type flip-flop
T74LS74B1 Flip Flop, Dual, D Type
LM393N Comparator, Dual channel, Open drain/collector, 36V, DIP, 8-pin
UM91210 TONE/PULSE DIALER
TDA3730 Frequency Demodulator and Drop Out Compensator for Video Recoders
KIA7303P ???
KIA7343AP ???
MC6802P Microprocessor (8) With Clock and Oprtional RAM
EF6821P PERIPHERAL INTERFACE ADAPTER
ET2716Q-1 16,384-BIT (2048 x 8 – 64k) UV ERASABLE PROM MEMORY COMPONENTS
TC4001BP QUAD 2 INPUT NOR GATE
CD4093H CMOS QUAD 2-INPUT NAND SCHMITT TRIGGERS
HFE4017BP CMOS HEX D-TYPE FLIP-FLOP
Z0853006PSC Communication Controllers, Serial Communication Controller
NE555N Timer
9741J Op-Amp
LM386L LOW VOLTAGE AUDIO POWER AMPLIFIER
M055B1 1 of 16 Decoder
M1025B5CA
ULN2803APC High-Voltage, High-Current Darlington Arrays (500mA per pair)
TDA7000 FM Receiver demodulator
Еве јас што имам
некој се на латиница напишани некој на кирилица тоа е затоа што тие се така во оригинал  ;D
к589ИР12 x 5 парчиња керамичко тело 24 нозе
ММЕ UB8563D x 1 парче керамичко тело 40 нозе
MME UB8560D x 1 парче керамичко тело 40 нозе
ММЕ UB857D x 1 парче ( од тука надолу нема д апишам тело пошто сите се керамички ако има некое пластика ќе наведам ) 28 нозе плоснато тело ( незнам како се вика )
155Л1x 32 парчиња  ;D 14 нозе
74S405 х 2 парчиња 16 нозе
589АП16 x парчиња 16 нозе
КР565РУ2 х 16 парчиња 16 нозе
EMS4116-3 х 60 парчиња  ;D 16 нозе
D274D х 4 парчиња 7 нозе
INS/DP8212N х 4 парчиња од тие плоснатите лежишта 24 нозе
EL3216 x 2 парчиња 16 нозе
SN74LS244N x 3 парчиња 20 нозе
EL7400J х 4 парчиња 14 нозе
7404 х 2 парчиња од кој едно е пластика 14 нозе
565У2 х 1 парче
овие се пластика подолу и мака ми е да ги бројам нозете
M514256A-80R ги имам 10 парчиња
Em51256C-15PL ги имам 9 парчиња
IS61LV256-15N ги имам само 2 парчиња
MME U555C х 2 парчиња керамичко куќиште
ММЕ U855D х 1 парче 4 нозе керамичко пакување
 PIC18F2550 x1 парче пластика 28 Нозе
PIC16F877 x1 парче пластика 40 нозе
PIC16F628 x 3 парчиња 18 нозе пластика
PIC16F84 x 3 парчиња 18 нозе пластика
PIC12F675 x 3 парчиња 8 нозе пластика
PIC12F629 x 1 парче пластика 8 нозе
и имам ушт енекои ама мака ми е да ги пишам  :P
Offline nCounTr
  • Почивај во мир
  • Дипл.Ел.Инж.
Јас имам најмалку за смешка сум :D Но полека ќе ја зголемам.
4xPGA2310
1xPIC18F4550
АМАН ЧИТАЈТЕ ПРАВИЛA
Offline SaleSk
Јас искрено да ви кажам имам толку многу што ни сам не знам што све имам...Сакав едно време да направам список, зза да имам увид што све имам, но во недостаток на време не успеав тоа да го сторам...И ден денес за жал подсредени ми се само електролитите и отпорниците...Транзисторчињата и така и така...Оние што најчесто се користат од типот бц 639/640. бд 139/140, бд 243/244, бд911/912, бу508 а, д, бу 2508, 2520, 2525 и слично.
Многу од деловите ми се наоѓаат и на шасии и полесно ми е да извадам од шасија него да ми стојат некаде во фиока...Бидејки гледајќи ја шасијата знам што имам а што немам на неа  ;D
Offline Aleks
Одг: Интегрирани кола - ваша колекција
« Reply #5 on 26.04.2010, Monday, 14:25:29 (Edited 26.04.2010, Monday, 15:11:10) »
Денеска малце ги подсредив интегралците, ги ставив на сунгер, фотка :
http://i39.tinypic.com/j8ze2r.jpg
Offline nCounTr
  • Почивај во мир
  • Дипл.Ел.Инж.
Ажурирање:
4xPGA2310
1xPIC18F4550
1xW29C020-12
PIC18F4550 DIL или SMD?
Offline nCounTr
  • Почивај во мир
  • Дипл.Ел.Инж.
Offline Aleks
Случајно некој дан има 8155, 8156, 8255, 8355, 8755 Интерфејс за Intel 8085 ? Ми треба за идеја што ми текна да оживеам некој 8085 процесор.
Пинг пинг :))))
Offline Gestak
нема да се купат нови??
Нема, многу тешко да ги најдеш сега околните елементи за 8085 систем, останаа само во теоријата :)
Offline MAKEDONIA
gi imaam samo treba da gi najdam vo sobata deneska ke pobaram
Да додадам во колекцијата дека успеав да набавам Intel 80286 само што е произведено од Simens хаха
На времето (пред околу 20 години), многу други компании за миркочипови произведувале Intel-ови процесори, нека не те чуди ако начекаш и Intel-ов процесор произведен од AMD, е потоа Intel (некаде околу 1992, 1993) почнуваат друга политика и ги повлекуваат лиценците за производство на процесори од страна на други компании. Во оваа ситуација, многу компании (меѓу кои и AMD) се побунуваат и почнуваат правен спор со Intel кој го губат. Па така AMD почнуваат сами да си изработуваат нивни процесори ;).
Ова чисто како историјат, sorry за off-topic ;).
