Author Topic: Windows 7 Registry Tweaks  (Read 744 times)
« Opened on 27.05.2015, Wednesday, 01:01:30 »
Поголем дел од tweak-овите се registry tweaks, па затоа така и ја крстив темата. Некои се и batch скрипти, но релативно мал дел ;). Поголем дел од овие tweak-ови функционираат и на Windows 8 и 8.1 ;).
Еве листа од tweak-овите во attachment-от ;).
Add ''Device Manager'' To The Right Click Context Menu On My Computer.reg
Add ''Open command window here'' To The Right Click Context Menu.reg
Add ''Open with Notepad'' To The Right Click Context Menu.reg
Add ''Register'' And ''Unregister'' To The Right Click Context Menu On DLL And OCX Files.reg
Add ''Registry Editor'' To The Right Click Context Menu On My Computer.reg
Add ''System Properties'' To The Right Click Context Menu On My Computer.reg
Add ''Take Ownership'' To The Right Click Context Menu.reg
Disable Automatic Updates.reg
Disable AutoPlay.reg
Disable Clear Page File At Shut Down.reg
Disable ClearType In Microsoft Office Word 2003.reg
Disable Creation Of ''Desktop.ini''.reg
Disable Creation Of ''Thumbs.db'' Files.reg
Disable Hibernation And Creation Off ''hiberfile.sys'' (Run As Administrator).bat
Disable Java Update (x86 Java on x64 OS).reg
Disable Low Disk Space Warning In Tray.reg
Disable Program Compatibility Assistant (''This program might not have installed correctly'' Message).reg
Disable Taskbar Pinning.reg
Disable Taskbar Preview.reg
Disable The Microsoft Web Service Popup When Opening Unhandled File Associations.reg
Disable The ''These files might be harmful to your computer'' Prompt When Browsing Network Files (x64) (Read Instructions In Registry File).reg
Disable The ''These files might be harmful to your computer'' Prompt When Browsing Network Files (x86) (Read Instructions In Registry File).reg
Disable Thumbnail Preview In Taskbar.reg
Disable UAC.reg
Disable Windows Hotkeys.reg
Disable Windows Startup Repair (The ''Start Windows Normally'' Screen).bat
Disable Windows Update Service.bat
Enable Automatic Mounting Of New Volumes.bat
Enable Automatic Mounting Of New Volumes.txt
Enable Automatic Updates.reg
Enable AutoPlay.reg
Enable Clear Page File At Shut Down.reg
Enable Program Compatibility Assistant (''This program might not have installed correctly'' Message).reg
Enable Taskbar Pinning.reg
Enable Thumbnail Preview In Taskbar.reg
Enable UAC.reg
Enable Windows Hotkeys.reg
Enable Windows Update Service.bat
Fix Desktop Refresh Bug.reg
Fix Slow Shortcut Resolution If The Shortcut Doesn't Exist.reg
Remove ''Bitmap image'' From New Context Menu Item.reg
Remove ''Briefcase'' From New Context Menu Item.reg
Remove ''Burn'' Button From Windows Explorer Command Bar.reg
Remove ''Compressed (Zipped) Folder'' From New Context Menu Item.reg
Remove ''Compressed (zipped) Folder'' From The Send To List.bat
Remove ''Contact'' From Right Click Context Menu.reg
Remove ''Device Manager'' From The Right Click Context Menu On My Computer.reg
Remove ''Documents'' From The Send To List.bat
Remove ''Fax Recipient'' From The Send To List.bat
Remove Full Row Select And Change Back To XP Style Icon Spacing (Read Instructions In Registry File).reg
Remove ''Include In Library'' From Right Click Context Menu.reg
Remove ''Journal Document'' From Right Click Context Menu.reg
Remove ''Library'' From Right Click Context Menu.reg
Remove ''Mail recipient'' From The Send To List.bat
Remove ''Open with Notepad'' To The Right Click Context Menu.reg
Remove Pinned Programs In The Start Menu.reg
Remove ''Register'' And ''Unregister'' To The Right Click Context Menu On DLL And OCX Files.reg
Remove ''Registry Editor'' From The Right Click Context Menu On My Computer.reg
Remove ''Rich Text Document'' From Right Click Context Menu.reg
Remove ''System Properties'' From The Right Click Context Menu On My Computer.reg
Remove ''Take Ownership'' From The Right Click Context Menu.reg
Remove The Search Bar, F3 And Ctrl + F Search Function.reg
Remove The Word  ''Shortcut'' When Creating New Shortcuts.reg
Restore ''Bitmap image'' From New Context Menu Item.reg
Restore ''Briefcase'' From New Context Menu Item.reg
Restore ''Compressed (Zipped) Folder'' From New Context Menu Item.reg
Restore ''Contact'' From Right Click Context Menu.reg
Restore Creation Of ''Thumbs.db'' Files.reg
Restore ''Include In Library'' From Right Click Context Menu.reg
Restore ''Journal Document'' From Right Click Context Menu.reg
Restore ''Library'' From Right Click Context Menu.reg
Restore ''Rich Text Document'' From Right Click Context Menu.reg
Restore The Microsoft Web Service Popup When Opening Unhandled File Associations.reg
Restore The Search Bar, F3 And Ctrl + F Search Function.reg
Restore The ''These files might be harmful to your computer'' Prompt When Browsing Network Files (x64) (Read Instructions In Registry File).reg
Restore The ''These files might be harmful to your computer'' Prompt When Browsing Network Files (x86) (Read Instructions In Registry File).reg
Show Partition Letters After The Label.reg
Show Partition Letters Before The Label.reg
