Аналогна електроника => Радио техника => Радиоаматери => Topic started by: DX-er on 04.06.2016, Saturday, 21:34:39
Се работи за CW предавател со многу мала моќ а за работа создава ел. енергија од гласот на оној кој го користи.
Со овој предавател постигнале 1609km домет.
(http://qrznow.com/wp-content/uploads/2016/04/voice-powered-radio.jpg)
Оригиналниот текст на англиски:
Many of us tried the old “Two tin cans connected by a string” experiment as kids. [Michael Rainey, AA1TJ] never quite forgot it. Back in 2009, he built “El Silbo”, a ham radio transmitter powered entirely by his voice. El Silbo is a Double Side Band (DSB) transmitter for 75 meters. While voice is used to excite the transmitter, it doesn’t actually transmit voice. El Silbo is a CW affair, so you should bone up on your Morse Code a bit before building one. Like many QRP transmitters El Silbo’s circuit is rather simple. A junk box loudspeaker is installed at the bottom of the can to convert voice power to electrical power. The signal is passed through a step up transformer, and used to excite a 75m crystal. Two NPN transistors (in this case MPS6521) pass the signal on through a second transformer. The signal is then routed through an LC network to the antenna
Видео презентација:
Извор:
http://qrznow.com/amateur-radio-transmits-1000-miles-on-voice-power/
